What is the bake bleeding sequence?
Who.Am.Eye.2716
Im looking to do an HPDE day for a few hours and wanting to replace the factory fluid.
Before I do what I think it is, would like to know if its different than the standard RR, LR, RF, LF
Matth1000
Matthew
Perth, Western Australia
Investor
I think with these these modern ABS circuits, its not as important as each wheel is independant to eachother. Even though I alsways do furtherest to shortest in relation to the master cylinder.
@Thefunk
Sometimes brake line length can change from location and where the ABS system is
Maybe its LR, RR, RF, LF 🤷🏽‍♂️
I guess you'd have to trace the brake lines under the car to see how they're routed, but the rule applies regardless. Otherwise you'll introduce air into the system between calipers.
up4speed
According to the shop manual, it's not the standard farthest to closest pattern.
On the Z it's:
Right rear - Left Front - Left Rear - Right Front
I thought it was strange, but just did it last week in preparation for a track day, and all went well.
And the bleeders are 70 in/lbs. (5.833333333333333333333 ft/lbs, LOL)
See attached PDF, I highlighted the part that writes the proper bleeding order:
On the Z it's:
Shop manual? That doesn't look like official Nissan documentation.😂
up4speed
Haha, that's because I printed the page, then scanned with my phone and made a PDF with my notes app. Then edited it to highlight that area. 😄
RobotAZ
TN
Utility Consultant
Has nothing to do with air. It’s about replacing old fluid.
