Z Tacho red line.
Stefanovich
steve
2023 Proto Z
Hi Z fam, can anyone explain why the Z Tacho red line starts at 7k and goes to 8.5k but the engine is rev limited to around 6.8k?
Koryak
John
Colorado
2024 Z Performance MT, 2005 Mini Cooper S
retired telecom instructor
Keep in mind the tach is showing a graphic representation of what the digital electronics are doing. Nissan likely sets the rev-limiter conservatively and may be adjusting for gearing and rate of RPM increase, like lower in lower gears.
Having a range of over-rev like to 8.5k is just old school tradition. Hopefully nobody ever sees this unless the ECU is tuned or they botch a 6 speed manual down shift. The Z's stock bucket followers and camshafts are optimized for max HP slightly below red line.
Most vehicles I've owned have the indicated redline a few hundred revs higher than the fuel cut.
Sometimes automatic transmission programming will shift even sooner than the fuel cut, can't have the automatic shifting too close to fuel cut.....
