Thanks for the input; very helpful. I'm planning on doing the same.Yes, the car had about 1200 miles on it before I put on a set of Z1 sway bars...I ordered them before I even picked up the car. I've had many Z's before including two 370Z's. I had ZERO doubt that I'd be unhappy with the amount of body roll on the stock Z34 chassis. The Z1's are good, but likely not better than the other usual aftermarket brands (I've had Whites, Eibachs, and Stillens over the years). On these Z1's, I set them up on the stiffer of the two holes. That did eliminate the body roll but also harshed up the ride a bit more than I wanted. I plan to reset to the softer hole when I get around to it.
