Did you remove any of the trunk plastics to do this, or just the spare tire stuff and subwoofer?$29 worth of Amazon sound deadening and about 30 min, seems to have made a nice improvement.
I am a bit underwhelmed by the sound system in the car. I'd rather not have to completely redo it. Does the sound deadening in the trunk help in that regard?Link to material and how many sheets or square footage do you need for trunk?
Did you just replace the sub any none of the other speakers? What sub did you use?I can’t comment with much integrity as I removed the bose sub. Sound deadening “should” certainly help a sound system by eliminating background noise, if I’m not mistaken that is the point, but I’m of the opinion that nothing can help that Bose sub sound any better, its junk and they should be ashamed to put their name on it and/or call it an “upgraded sound system”.
I didnt even list mine on eBay as they are listed for ~$50 and prob cost more to ship it.
I went and added sound/heat proof in the spare tire area. It was bare metal; as you can see. The other pictures are after the addition. It made a considerable difference. We'll see what happens once I get the ASE turned off.$29 worth of Amazon sound deadening and about 30 min, seems to have made a nice improvement.
OMG, you did an amazing job!!I went and added sound/heat proof in the spare tire area. It was bare metal; as you can see. The other pictures are after the addition. It made a considerable difference. We'll see what happens once I get the ASE turned off.
See...
I'm not planning on doing the panels. I don't know how to measure the decibels without getting a special device for that.OMG, you did an amazing job!!
Do you plan to do the panels as well?
Can you already hear a noticeable difference?
The guy said he will add a second layer…
Would you mind measuring the noise level at 55–65 miles per hour?
but ASE isn’t supposed to help reducing the (engine) noise or something ?
If youI'm not planning on doing the panels. I don't know how to measure the decibels without getting a special device for that.
I thought that the ASE was supposed to enhance the noise from the outside?
Tks ! but glad to hear there is a positive difference already !I'm not planning on doing the panels. I don't know how to measure the decibels without getting a special device for that.
Got ya!If you
If you have an Apple Watch there is a function to measure the Db it is not 100% ultra reliable but it already gives an indication.
I mixed up I was thinking about the ANC and it seems that it about the low frequencies
“Active Noise Cancellation technology uses a microphone in the headlining to identify undesirable low-frequency engine sounds and neutralise them with sound waves of the opposite frequency. The result – a quieter driving experience that still preserves the invigorating sounds of the engine.”
