zRedBaron
- Thread starter
- #1
PFA - A couple shots of my new Z at Willow Springs International Raceway during ZCON 2023 in So Cal.
If you're new to owning a modern Z you may not know that the VDC button does not completely disable traction control on your car.
The 370z required splicing a wire/switch to a yaw sensor, which would allow you to completely disable VDC/TC leaving only the ABS active and functioning.
I've seen and read that you can do the same with the RZ34 and the VR30 equipped Q50/60 but it's a little different.
Method 1: Some claim you can hold the VDC button down for like 10 seconds and that should do it. After doing so you will notice that toggling the button does nothing and does not indicate if VDC is enabled or disabled.
Method 2: With your foot on the brake pedal, reach down under the dash to where the brake pedal is and find the brake light switch on the pedal assembly. Hold it down for about 10 seconds or so until a light on the dash turns on.
Disclaimer: I DO NOT recommend inexperienced drivers or drivers who are unfamiliar with handling a car at the limits of traction to try this.
I'm asking this in the tracking section of this site because drivers who are seeking to get the most out of the car are going to need to disable the nannys. Nothing kills your lap times like an invasive OEM TC system
